where can I get a crank sensor grommet?
Old Sep 28, 2019 | 10:31 AM
chris martin's Avatar
chris martin
Originally Posted by ridler16
So I don't need it? Why not? I believe I need it, the engineers thought I needed it. Ok so I technically do not need it 'cuz I can make a suitable replacement. I believe I need it to keep dirt, dust, grime road salt and water out of a transmission I spent over $400 and 35 hours on, cleaning and building and measureing 'cuz the 2 weight governor is 5/100ths narrower than the three weight governor (and the three weight scraped the housing) and those OD's with different weights are twins but not identical. The input shafts are of different sizes in the front. My original pump would not fit on my rebuild. But I knew that through measurement and changed the shafts. Anyway i guess no junk will get into my tranny but it could work it's way to that crank sensor, So would someone please give me a logical reason why that grommet is not a needed item. I'm just being cautious!!
Thanks folks
Ridler
I found one at the pick and pull
