Voltage Drop
Old Oct 20, 2009 | 05:50 PM
NoClue's Avatar
NoClue
Default Voltage Drop
2000 Dodge 1500 4x4 Sport P/U 5.9L. While driving, voltage gauge bottoms out; I pull over, turn off engine and upon re-start the gauge jumps to about 12-volts; a few blocks later same thing happens. I repeat this process 2-3 times. Eventually upon re-start the gauge goes up to around 14 volts (which is normal) and all is well but...all of a sudden the gauge bottoms out and I start the process over.
Engine RPM's have no effect, new battery, this happens in wet or dry conditions, engine temp does not appear to be a factor, I checked and cleaned alternator terminals. What have I missed?
Old Oct 20, 2009 | 07:23 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Oct 20, 2009 | 08:51 PM
Salex007's Avatar
Salex007
this had happened to me, check for a loose wire and if not it is probably your alternator. I got mine tested and it gave off enough juice to pass but was failing on and off. More than likely that if you just got a new battery.
Old Oct 23, 2009 | 06:25 PM
NoClue's Avatar
NoClue
I checked the wires, all was well, so I replaced the Alternator, problem solved. The intermittent failures thru me off; usually a failing alternator causes lights to dim. Live and learn. Thanks for responding.
Old Oct 23, 2009 | 08:43 PM
Augiedoggy's Avatar
Augiedoggy
was probably the internal regulator failing....that would cause your symtoms if it was sticking....thanks for letting us know what solved it!
