Sound of water "swishing" under my dash!!!
Old Oct 23, 2009 | 10:12 PM
firefytr30215's Avatar
firefytr30215
Default Sound of water "swishing" under my dash!!!
I have just installed a new radiator in my 2001 1500 with 5.2 and after refilling the radiator I now have the sound of water sloshing upon acceleration under my dash. Could this be from the heater core? If so how can I fix this? I just bought this truck and discovered it had a blown head gasket and bad radiator. I cant afford the time right now to pull the head so I put in a bottle of Bars Leaks Head Gasket Sealer. It seems to be sealing up the leak slowly but was wondering if this could have anything to do with my problem stated above.
Thanks
Old Oct 23, 2009 | 10:33 PM
moparama's Avatar
moparama
Id check your coolant level and make sure its up to par. if not i know you said you had a head leak make sure its not in oil (pull out dipstick will be milky like). feel carpet is it wet? if so may be heater core then
Old Oct 23, 2009 | 10:47 PM
Miami_Son's Avatar
Miami_Son
Not to be rude, but what part of "this thread is not for posting of general questions" did you not understand? And then you go and start a new thread with the exact same question. Not a great way to start a relationship.
Old Oct 23, 2009 | 10:52 PM
CSXfan's Avatar
CSXfan
The sound you're hearing is air in the cooling system. It won't hurt anything, but it may cause some heating issues. You need to "burp" the air out of the system. I know there's a certain way to do this, but I'm not exactly sure what it is. Somebody else will chime in.
Old Oct 23, 2009 | 10:54 PM
moparama's Avatar
moparama
who me?
Old Oct 23, 2009 | 11:02 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by moparama
who me?
No, the OP. I did merge your Woohoo! post with the original oil pressure thread so that anyone that was following it can see how you resolved it.
Old Oct 23, 2009 | 11:05 PM
moparama's Avatar
moparama
yeah wasnt sure if i should put it there or what that was actually started by another guy i just tossed in my 2 cents thats all but thank you
