blower motor resistor
Old Oct 24, 2009 | 10:39 AM
Eddielx's Avatar
Eddielx
Default blower motor resistor
I had replaced 2 motor resistors in the past 2 months and on this third one I noticed a solder joint that had came apart.Is that a built in type of a fuse and that would mean I have a short somewhere or is it a bad design or a bad part again.I resolder it and for right now it works.
I replaced the blower motor because it was the reason the relay got too hot.
BAD SOLDER JOINT
REsolder the joint
Old Oct 24, 2009 | 10:41 AM
95RAM360's Avatar
95RAM360
id say check all the wires, maybe a bad ground
Old Oct 24, 2009 | 11:34 AM
Augiedoggy's Avatar
Augiedoggy
sounds like somethings causing it to heat up too much ....could be poor wiring connections causing too much resistance.
