how do you know if your truck has a lift
Old Oct 26, 2009 | 11:12 PM
shaneballance's Avatar
shaneballance
Default how do you know if your truck has a lift
ok i have a 1996 dodge 1500 4x4 with a 5.2 you mite see in the pic .i have tire size 31/10.5/15 on it ...i just got this truck for 1,000 of off of a guy it looks like it has a lift ,,,but if it does how do you tell.
Attached Thumbnails how do you know if your truck has a lift-lift-truck-002.jpg   how do you know if your truck has a lift-lift-truck-003.jpg   how do you know if your truck has a lift-lift-truck-004.jpg   how do you know if your truck has a lift-lift-truck-005.jpg   how do you know if your truck has a lift-lift-truck-006.jpg
Old Oct 26, 2009 | 11:29 PM
Cereal Killer's Avatar
Cereal Killer
Post a picture or some measurements and we'll tell you
Old Oct 26, 2009 | 11:52 PM
Sheriff420's Avatar
Sheriff420
post a side view picture so we can see the leaf springs and the top of the coil springs.
Old Oct 27, 2009 | 01:54 AM
JackJ's Avatar
JackJ
You can look at the rear springs, if you have two blocks under them, you probaly have a lift. Also look at you suspension linkage, if it is aftermarket it will usualy have the manufacturer name on it.
Old Oct 27, 2009 | 03:28 AM
helms's Avatar
helms
if a good kit is installed properly, you shouldnt be able to tell its not factory unless you measure it.
Old Oct 27, 2009 | 05:16 AM
JackJ's Avatar
JackJ
Unless it is mine, where the PO hacked up the front wheel wells to install taller shock and spring mounts to lift it.
Old Oct 27, 2009 | 05:59 AM
95RAM360's Avatar
95RAM360
the 31 10.5 isnt that big of a tire, (ran those on my 93 nissan d21)
Looking at it, do you have alot of excess room for bigger tires? if there alot of room most likely you have a lift.
or do what everyone else has said, and get a side pic, and we'll be able to tell
my tires are 31.8in. and look at the room i have, do you have more than that?
Old Oct 27, 2009 | 10:18 AM
shaneballance
i added some pics so ya can see..its got blocks on it,but there metal with a stopper not like the lifting blocks i see all the time,from the ground to the bottom of the of the boddy at the door is 19ins,with 31/10.5/15
Old Oct 27, 2009 | 10:37 AM
SpcD1500's Avatar
SpcD1500
that looks like stock suspention components to me, except your shocks. those are stock blocks and that arm is to hit you bump stops.
Old Oct 27, 2009 | 10:50 AM
xskylinedx's Avatar
xskylinedx
Originally Posted by SpcD1500
that looks like stock suspension components to me, except your shocks.
I agree
