stock exhaust inside dia. and outside dia?
Old Oct 30, 2009 | 10:11 AM
Mudshack's Avatar
Mudshack
Default stock exhaust inside dia. and outside dia?
I am hoping to buy a Flowmaster 50 muffler, and know that it will be shorter than my stock garbage can. But my question is...what is the inside diameter of the stock pipe I would be plugging the 50 into? Will it slide right in, and then I can clamp the stock exhaust to it? What size pipe should I be getting to go from the flowmaster to the stock pipe behind it? (assuming that section of pipe is a female/female pipe.
What do you guys suggest?
Old Oct 30, 2009 | 10:44 AM
95RAM360's Avatar
95RAM360
i believe the piping is 2 1/4in OD at least mine was when i straight piped it
Old Oct 30, 2009 | 11:16 AM
AlabamaRam95's Avatar
AlabamaRam95
2 2" going into the cat, 1 2.5" coming out and going to the flow50, 2 2.25" coming ouf of the flow50
thats what i have...and i love the 50
Old Oct 30, 2009 | 12:08 PM
Mudshack's Avatar
Mudshack
AlabamaRam95. That doesn't help me. I know that it is 2.5" pipe coming into the muffler and 2.5" going out. But that doesn't tell me if the pipe is 2.5" inside diam and the 50 is 2.5" outside diameter? Or visa versa.
I want to by the 50 and some a section of about 10" straight pipe. So that I can just slide everything together and clamp it down. Every place asks me about Inside Dia. or Oustside Dia.? And I have had to say......er...I dunno.
Am I the first one to attempt this? I mean, buying the entire flowmaster dual exhaust would be great, but I am on a budget. And there isn't any performance increase throwing dual pipes back from a single muffler. AS far as I can see, that is.
Old Oct 30, 2009 | 12:13 PM
95RAM360's Avatar
95RAM360
the muffler is 2 1/2 OD, and the stock pipe is 2 1/4 OD
Old Oct 30, 2009 | 12:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The muffler is inside diameter. And the pipe in front is Outside diameter. Buy a pair of cheap plastic calipers.
Old Oct 30, 2009 | 12:19 PM
95RAM360's Avatar
95RAM360
Originally Posted by zman17
The muffler is inside diameter. Buy a pair of cheap plastic calipers.
im goin off the flowmaster 44's which is OD. At least the one i looked at was, so i thought these were the same, but you have one so you would know
Old Oct 30, 2009 | 12:33 PM
zman17's Avatar
zman17
My 50 series is 3" I.S. diameter going in. So he needs to measure the pipes to be sure instead of everyone guessing.
Old Oct 30, 2009 | 01:21 PM
Weldor's Avatar
Weldor
I'm going to let you in on a little secret tool called a tape measure, there great for measuring things like ID and OD on pipe...sorry I could'nt help myself. But ya me and my buddy both dumped our exhaust, its cheap, simple and sounds good. Mine was 2 1/2 OD I believe, but your better off measuring yourself, takes less time then it did starting this thread. And make you clamp and weld it!
Old Oct 30, 2009 | 01:32 PM
dodgeram07's Avatar
dodgeram07
i dont think he understands... they say he has a 2.5 pipe you buy a 2.5 muffle "because" the muffler is fraird a little and will side over the pipe to be clamped or welded,, so realy the muffler is larger than 2.5 so it can side over
im just reading into what his guy said i maybe wrong but i think that wanted he wanted
so go take zman addvise and go measure,,, soif its 2.5in get a 2.5 muffler if 3in get a 3in muffler
