What oxygen sensor????
Old Nov 4, 2009 | 08:26 PM
feldnerpa's Avatar
feldnerpa
Default What oxygen sensor????
Ok, here is my deal. I have a 2001 1500 4x4 regular cab, 5.2L, Manual. I had an issue with it stalling and sputtering and what not around 2k. After running for about 10 minutes it would be fine. A dodge tech told me to replace the intake plenum gasket, which seemed to fix the problem for about a day. I do have a check engine light still on indicating my upstream oxygen sensor. I can not get the correct sensor for the life of me. I have now purchased 3 different ones and everyone I get in the mail is the wrong one. I one sensore right before the cat converter and one after. Both have the same square connector. The one most places spec out for my vehicle have a round style connector for before the converter. My stock sensor measures about 12 inches from the threads to the end of the pigtail. I have a Bosch part # 13122, and also a Denso 234-4076. Neither of which are correct.
HELP!!!!!!!!!!!!
Thanks guys
Old Nov 4, 2009 | 08:30 PM
95RAM360's Avatar
95RAM360
welcome to the forum
i was actually looking at oxygen sensors last week,(Upstream, before CAT) for i have just repaired my plenum. i went to autozone, and the had the correct one, in fact it looked exacally like the one i had on there to begin with (stock 02sensor) so i dont know if you've tried AutoZone but the have the round connector
Old Nov 4, 2009 | 09:09 PM
AlabamaRam95's Avatar
AlabamaRam95
just cut the harness off and hook it to the new sensor.
Old Nov 4, 2009 | 09:11 PM
feldnerpa's Avatar
feldnerpa
yup, autozone was the first place I tried. But what you said is what my problem is. Everyone sells me the round style connector. Mine is square.
Old Nov 5, 2009 | 03:00 AM
wjxavier's Avatar
wjxavier
then like said above...cut the wires off...and splice them together(if you know how to do that kinda thing)
Old Nov 5, 2009 | 06:38 AM
95RAM360's Avatar
95RAM360
im sorry im misunderstood, i thought you wanted the round tip....but yea do like everyone else is saying, and if you get a universal with a square top...those are easy to wire in.
Old Nov 5, 2009 | 07:34 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Take it back to the parts store and look at ones from different years. They changed the plug a couple times.
