Weird belt problem
Old Nov 5, 2009 | 03:57 PM
PurplDodge's Avatar
PurplDodge
What is the condition of the belt? How old is it?
Old Nov 5, 2009 | 03:58 PM
95RAM360's Avatar
95RAM360
replaced the belt when i did water pump 2 months ago...belt looks brand new, no cracks or anything
Old Nov 5, 2009 | 04:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Does the belt and all the pulleys have the same amount of ribs? There are 6 and 7 rib belts and pulleys.
Old Nov 5, 2009 | 04:38 PM
95RAM360's Avatar
95RAM360
yes, i did check that as well, and its all the same
Old Nov 5, 2009 | 05:02 PM
zman17's Avatar
zman17
Well I don't know what to tell you, something has to be bent or not installed right. If it didn't do it before the plenum fix, then one can only come to the obvious conclusion.
Old Nov 5, 2009 | 05:20 PM
AlabamaRam95's Avatar
AlabamaRam95
sorry....double post.
but ill use it...if you look down on the pulleys all lines up right? what if you look at them from the left and or right...do any tilt?
Old Nov 5, 2009 | 05:21 PM
AlabamaRam95
alternator and ac pump...are they installed correctly? like are they level? if one is tilted forward or backward that would cause that. that is what i mean by plumb.
Old Nov 5, 2009 | 05:24 PM
zman17's Avatar
zman17
Right, there has to be a spacer or bracket not on right.
Old Nov 5, 2009 | 05:29 PM
AlabamaRam95
sounds to me like 95Ram360 has been introduced to murphy's law
ignition wire
blinkers
doors
axle seal
trans mount
balancer
brake lines
valve covers
plenum
front end
shackle
serp belt
dude...how much did you pay for this truck...?
Old Nov 5, 2009 | 05:38 PM
zman17's Avatar
zman17
Don't forget rusted rocker panels, I forget what he paid for it, but it's in the How much did you pay thread.
