View Poll Results: Locker or LSD
Locker.
13
86.67%
LSD.
2
13.33%
Voters: 15. You may not vote on this poll
Lock the rear or lsd?
Old Nov 5, 2009 | 07:16 PM
lastrights's Avatar
lastrights
how does lockers run on dry pavement
Old Nov 5, 2009 | 07:23 PM
big.red.ram's Avatar
big.red.ram
lockers engage as soon as u put ur foot on the gas so u have 100% torque at both wheels and when u let off the gas it disengages so u can turn and what not. i believe thats how they work. someone will correct me if im wrong
Old Nov 5, 2009 | 07:25 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by dodge15004x45.9
I hooked a guy up with a site for front and rear gear with 2 install kits for 570 and for an extra 60 you can get rear yukon.
i saw that....but I already have 4.56 gears....its just my rear axle pinion bearing went so I get a whine when I take my foot off the gas...and i found pieces of a shim in the housing...my gears still look good though...
I just discovered I have the lsd too.
Weldor's Avatar
Weldor
I thought you could get lockers that work manually. Cable lockers like ox come with a lever you pull when you want it to lock out.
Old Nov 5, 2009 | 07:28 PM
95_318SLT's Avatar
95_318SLT
Yup, this is it in a nutshell. Torque transfer through the locker locks it up, and a lack of torque unlocks it, but there is a little bit of leeway for making a turn from a stop... as long as you go easy on the gas you can keep it from locking up, otherwise making a turn from a stop would be a heck of a lot harder. From what I've heard, it takes some getting used to driving on pavement, but if you use it like you should, it won't cause any excess wear on the tires or drivetrain.
Old Nov 5, 2009 | 07:30 PM
95_318SLT's Avatar
95_318SLT
Well there are different kinds. The description he gave is an automatic locker. There are selectable lockers that use cables like you mentioned, or air, or electronics. The selectable ones work like an open diff until you manually lock it.
Old Nov 5, 2009 | 07:31 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Odds are that is where I'm going to get my gears from due to price.
Old Nov 6, 2009 | 01:55 PM
dodge15004x45.9
Bump.
Old Nov 6, 2009 | 05:03 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by 95_318SLT
True, but you need an open carrier for the "lunchbox" lockers... they won't fit right in the LSD carrier.
Actually the Powertrax No-Slip is made for LSD carriers in some applications, I believe the 9.25 is one of them.
Locker gets my vote of course.
Old Nov 6, 2009 | 10:18 PM
lastrights's Avatar
lastrights
lockers can you still light the tires up ?? i like punching it sometimes going around bends
