CEL code p0138 ????
Old Nov 5, 2009 | 10:40 PM
Mowhawk's Avatar
Mowhawk
Default CEL code p0138 ????
Soo i was driving back from training today, and it seems like one of my header to Y-pipe gaskets blew. Sounds liek im running straight pipes (sounds amazing btw should have taken a video). But now i have this CEL, i pulled the reader and all it gives me is no info ava. Is this a blank code? I cleared it to see if it will come back , so ill be finding that out tom. Any ideas??
Old Nov 5, 2009 | 11:08 PM
pcfixerpro's Avatar
pcfixerpro
code is for the after cat o2 sensor
Old Nov 6, 2009 | 08:27 AM
Mowhawk's Avatar
Mowhawk
Code going to be a problem while im driving? I cant get this fixed for a lil
Old Nov 6, 2009 | 08:37 AM
95RAM360's Avatar
95RAM360
is it running rough? if not keep running it. my CEL came on on the highway last night. stayed on the whole 2 hours. went to get it scanned, and when i actually got there, shut off the truck, then when i went to start it, the CEL was gone, so they couldnt read anything. it was weird. but it hasnt come on again. but if its running good, aside from the gasket problem, then leave it IMO
Old Nov 6, 2009 | 09:35 AM
Mowhawk's Avatar
Mowhawk
Its running fine. Just sounds like a beast. Thanks
Old Nov 6, 2009 | 10:00 AM
95RAM360's Avatar
95RAM360
disconnect the negative termial. then pull the headlight switch, and have it out for about 10 seconds. push it back in, and re-connect the terminal. I was told thats how you can reset them
Old Nov 6, 2009 | 10:40 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It's no big deal, that sensor just tells the pcm if the cat is working or not. And since you have an exhaust leak, I'm sure it's just throwing it off.
