how to tell if you have 2 or 4 wheel anti-lock breaks?
Old Nov 15, 2009 | 02:11 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by 011500Ram
DEFINITELY NOT TRUE. Ignore this post as it is 100% incorrect.
My 01 1500 has 2 Wheel ABS, front only.
Proof, please. You may have front ABS, but I doubt it is front only unless someone removed the rears.
http://www.allpar.com/model/ram/1994-ram.html
Old Nov 15, 2009 | 02:19 PM
011500Ram's Avatar
011500Ram
Originally Posted by Chrysler Build Sheet
CODE DESCRIPTION
S9AZ Deluxe Cloth 40/20/40 Bench Seat
APAS Monotone Paint
A05P 5.2L Engine(ELF)/4Sp Auto Trans(DGT)
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum FWAL Anti-Lock Brakes
Four wheel antilock brakes is exhibited as "FWAL/RWAL" or "AWAL".
Plus, I'm the only owner of my truck. I seriously doubt I took off non-existent parts.
You edited your post after I made mine... But allpar confirms what I said.
Old Nov 15, 2009 | 02:43 PM
Miami_Son's Avatar
Miami_Son
FWAL=Four Wheel Anti Lock, not Front Wheel Anti Lock, which is what you said you have. 2nd gen Rams were never offered with only front wheel ABS. The link I provided backs that up. My build sheet reads the same as yours and I most definitely have 4-wheel ABS.
Old Nov 15, 2009 | 04:09 PM
nathangfnd's Avatar
nathangfnd
wow. i thought i would come on here and see one post talking about it but im already up to 2 pages.
Anyways, Thanks for the info. plan on buying new wheel hubs and break calipers this week due to not going with more lift so no need for 1 ton axles and ive been driving with one caliper for about 8 months or so.
Old Nov 15, 2009 | 06:17 PM
011500Ram's Avatar
011500Ram
The terminology in the trucks service manual indicates otherwise.
Either way, I understand what you are saying, however the information Allpar provides is conflicting. It says that 4 Wheel ABS is optional in one place, and in another that they are standard with a differential sensor. Also, when you buy Hubs for these trucks, (I just went through this with my truck because they sent me the wrong hub) you have the option of getting the hub with 4Wheel ABS and 2Wheel ABS.
Regardless, I have 2 Wheel ABS, front only. When I mash the brakes, my front wheels do the ABS dance. the rear lock. It's been like that since 2001 when I bought it brand new.
Old Nov 15, 2009 | 06:28 PM
grox's Avatar
grox
I have a 94 and it definitely only has real wheel anti-lock brakes. It was also definitely standard issue.
Old Nov 15, 2009 | 06:51 PM
Miami_Son's Avatar
Miami_Son
Actually, if you read it closely you'll see where they say it became standard equipment on all 2500/3500 models with the 2001 model year and standard on 3500 models with the 2000 model year. On all others it was optional.
Old Nov 15, 2009 | 07:51 PM
VEETEN's Avatar
VEETEN
+1 with Miami
RWAL was standard on all 2nd Gens..
For most all p-ups RWAL was standard as these are the 1st to lock up.
Front only doesn't make sense.
Check you're rear pumpkin there should be the RWAL speed sensor mounted to the top.
Old Nov 15, 2009 | 08:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Front only would be rather dangerous, to say the least.
Old Nov 15, 2009 | 08:57 PM
Miami_Son's Avatar
Miami_Son
Exactly. The reason they are standard equipment on the rear is because it is too easy to lock up the rear brakes on an empty truck.
