flamethrower exhaust
Old Nov 15, 2009 | 10:36 PM
TIMIDONE's Avatar
TIMIDONE
I have no idea how they work but I'd be scared it destroys something on my truck! can those flames trace back into the engine?
Old Nov 15, 2009 | 10:50 PM
dakotas ram's Avatar
dakotas ram
these are a bad idea if you are shutting the engine down for gas cause when you do that, the gas washes the oil off the cylinder walls and into your oil breaking it down.......i saw a write up before that a guy used nos fittings and had a separate fuel line running to it
Old Nov 15, 2009 | 11:01 PM
Weldor's Avatar
Weldor
I've seen this done with just a spark plug and a switch, the guy also had a separate fuel line going to a small propane tank he had mounted in the bed. Takes some work but it can be done on the cheap.
Old Nov 15, 2009 | 11:29 PM
1fast2liter's Avatar
1fast2liter
yes the base of the system uses a propane tank. and a spark or ignitor in the tail pipe some how.. they force it threw then ignite it nothing goes thru the motoe itself..
Old Nov 16, 2009 | 12:04 AM
dakotas ram
actually some kits kill one of your plug wires to dump unburnt fuel
Old Nov 16, 2009 | 09:02 AM
charlie1935's Avatar
charlie1935
50 years ago we used a model T Ford coil to ignite them. One dollar at a junk yard.
The carburated engines usually were rich enough when you let off the accelerator at a higher RPM to make the fire show.
Old Nov 16, 2009 | 10:05 AM
95MaroonMonster's Avatar
95MaroonMonster
those systems look real cool on diesel trucks running stacks, heck i've seen it done on tractor trailer rigs before
Old Nov 16, 2009 | 11:13 AM
BlueBeast2's Avatar
BlueBeast2
Like others have mentioned it can be done. There was a guy on stangnet that did it to his Mustang. Some how his setup would basically turn off the coil so there was no spark and send all the fuel out the exhaust. It looked cool but not really a good idea. I talked to him about it a couple times wanting to do it to mine. He told me that his setup was bad for the motor. I assume its because of the washing the oil off the cylinders like has been said. I also think that it is possible for it to back feed if your not careful.
To do it right its gonna cost a good bit. My fear is setting my car or truck on fire so I gave up that idea
Old Nov 16, 2009 | 12:08 PM
dodgeboy1979's Avatar
dodgeboy1979
I've seen it done with an auxillary tank of pressurized gas tapped into the exhaust and a remote switch to open it like they use on the NOS bottles. Looks cool on classic cars but i wouldn't want to light a field on fire while i'm deer hunting lol.
Old Nov 16, 2009 | 09:05 PM
silverbullet-dodgeram's Avatar
well i do agree if i gotta spend a whole lotta money on it im not gonna do it lol i can use that money for go fast parts haha but if i could do it for $100 bucks or less id do it but i do wanna run a sepret fuel line and do the spark plug idea IM NOT GONNA DO MOTOR MODS ARE DO SOMTHIN THAT HARD ON MY MOTOR JUST SO I CAN SHOOT FLAMES but i was thinkin if i ran a sepreate fuel line and a spark plug (not ran off my truck coil) do u think the truck would push enough air to shoot flames (it will have a cat 2 inch pipe no muffler and duel 4x22inch tips ran out the corners at an angles) what yall thank?
