Please help my SS/T
Old Nov 18, 2009 | 03:37 PM
BlackRamSST's Avatar
BlackRamSST
Default Please help my SS/T
Has never had problems, till this morning. It was about 9:30, and 38*F. The starter turns over strong, but the engine will not start unless I hit the gas and hold it. i kept it this way till it was warm, then let go of the gas, and it died. When I am not hitting the gas, it still dies. It has the 5.9 liter V8, 117,7XX miles, many mods. It usually starts very strong.
I don't know if this is significant, but it has a very strong smell of gasoline, never smelled it so strong before.
Old Nov 18, 2009 | 03:42 PM
95RAM360's Avatar
95RAM360
fuel pump shot, and you flooded it would be my guess
and this marks my 1000th post lol
Old Nov 18, 2009 | 04:05 PM
lastrights's Avatar
lastrights
could be a sensor on throttle body ?? tps or something
Old Nov 18, 2009 | 05:17 PM
Laramie1997's Avatar
Laramie1997
I say TPS. Check it before you attempt to pull the fuel pump.
Old Nov 18, 2009 | 05:44 PM
notanexit7's Avatar
notanexit7
or the Iac. mine did the same thing. my mechanic said that sometimes it has trouble adjusting to the cold weather. I just bought a new one in leiu of cleaning it. haven't had a problem since
Old Nov 18, 2009 | 08:42 PM
moparama's Avatar
moparama
Or maybe gas leak and its not supplying enough fuel pressure
Old Nov 19, 2009 | 11:28 AM
BlackRamSST
Had water in the tank. Filled it up with more gas, and bought a solution from schucks. Thanks!
