front axle shaft seals
Old Nov 19, 2009 | 10:34 PM
canwrench's Avatar
canwrench
Default front axle shaft seals
I have a 2001 Quad cab 1500 off road package. My drivers side front axle shaft is leaking. I need to find some repair info, does anybody know of a web site that will help me out. Thanks Curt
Old Nov 19, 2009 | 10:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Download this, you'll be a lot better off with a manual.https://dodgeforum.com/forum/2nd-gen...tmas-guys.html
Old Nov 20, 2009 | 08:04 AM
dhvaughan's Avatar
dhvaughan
here's a diy with nice pics.
this link may or may not work. scroll around on the pavement tech articles. there are a lot of good ones.
http://www.pavementsucks.com/tech-article-3.html
Old Nov 20, 2009 | 09:23 AM
Sheriff420's Avatar
Sheriff420
on that link ^ you will need the hub article and the axle seal article.
and good luck, the drivers side seal is a bit of a pain.
you may want to change the passenger side also. about a week after i changed my drivers seal, the passenger seal started leaking.
should only cost you about 40$ to fix with fluid and both seals.
