Timing Chain Replacement
Old Nov 22, 2009 | 10:07 PM
dodge15004x45.9's Avatar
dodge15004x45.9
http://www.pavementsucks.com/tech-article-37.html
Old Nov 22, 2009 | 10:48 PM
lblair04's Avatar
lblair04
Sounds easy to mess up the timing...
Old Nov 23, 2009 | 02:30 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by lblair04
Big question: can I mess it up pretty bad if I have never done a timing chain before?
not too hard. but you'll need to buy/rent/borrow a harmonic balance puller. you'll also need an air gun to get the big crank bolt on/off. its torqued to about 140. once the crank bolt is loose, leave it threaded in a little ways to prevent the puller from damaging the threads in the crank.
the only 2 ways you can really **** up are...
yank on the outside edge of the balancer and ruin it.
screw up the threads in the shaft
use a screwdriver to hold the balancer from turning and crack the alum timing cover.
