A sad day.
Old Nov 22, 2009 | 12:33 PM
Rockyhigh360's Avatar
Rockyhigh360
Only 92k on the motor, I think a rebuild. If I can swing it.
Old Nov 22, 2009 | 01:39 PM
Rockyhigh360
Whew! So I disconnected the battery, rotated the crank clockwise, and heard some rattling in the rear of the engine. Took off the starter, flex plate cover, and what do you know, out falls a sheared bolt head!
All of my bolts holding the flexplate to the Torque Converter are snapped off! Not bad troubleshooting only 20 minutes in it. Looks like I get to keep my motor!!
Old Nov 22, 2009 | 02:06 PM
J415's Avatar
J415
Real glad to hear your problem had an easy fix!!! Since your gonna have to take the tranny out to fix that, it might be a good time to replace the freeze plugs as well.
Old Nov 22, 2009 | 08:02 PM
lastrights's Avatar
lastrights
can i buy your airgap
Old Nov 22, 2009 | 09:33 PM
silverbullet-dodgeram's Avatar
f**k a 6.7 they aint worth it put a 5.9 or a 12v in it it will be much better
Originally Posted by Rockyhigh360
Well, the Dodge had it's first ride on a tow truck this morning. My Engine seized on the highway about 10 miles from the house. It started to get a slight knock on a cold start-up that went away about 3 seconds after it ran. Well, today I guess whatever it was went out in a bad way. It started knocking hard out of nowhere so I pulled off and looked under the hood, saw nothing, then shut it off. Never started back up.
Oil is fine, water good, trans good, and yep, there's windshield wiper fluid too. I'll dig into it later next week as I have a work truck. The Ol' Lady say's I need to ditch the Beast and get a 6.7 Cummins. I think I have too much invested in the thing to walk away now. Any thoughts?
Old Nov 22, 2009 | 09:58 PM
halfamil's Avatar
halfamil
You have to wonder why the bolts are sheared,don't you?
Old Nov 23, 2009 | 12:03 PM
Rockyhigh360
I have upgraded almost everything from the rear main seal back to the axle shafts. When I slammed the new trans in, I re-used the T.C. bolts. I had to shim the T.C. off the flexplate about 3/16 to get my pump seal to seat correctly. I bet the factory bolts and the fact that they were in only 8 threads instead of 11 threads was the reason.
Whenever you upgrade one part, there is a direct effect on other parts. That's why you can keep your 8 inch lift and you 40 inch tires.
Old Nov 23, 2009 | 03:25 PM
95MaroonMonster's Avatar
95MaroonMonster
good to see ya will have it running again
