Lift!!!!!!
Old Nov 23, 2009 | 02:55 AM
RedRam99's Avatar
RedRam99
Default Lift!!!!!!
Well i just picked up a 01 ram 1500 4x4 its got a 3" body lift and cut fenders on superswamper 38x12.5x15...... anyway i want to lift it maybe 6" or more but im on budget how could i scrap together my own suspension lift kit...it has blocks under the rear leafs but the guy said that was stock idk if thats true.. could someone help me with what i will need and stuff?
Old Nov 23, 2009 | 03:29 AM
dodge15004x45.9's Avatar
dodge15004x45.9
New trac bar, drop pit arm, upper and lower control arm, coils/spacer, leafs/blocks.
Old Nov 23, 2009 | 03:32 AM
Weldor's Avatar
Weldor
They come with 3" blocks for the rear from the factory. And what is your budget like? That will effect things huge.
Old Nov 23, 2009 | 06:04 AM
95RAM360's Avatar
95RAM360
your tires dont look like 38's...or super swampers for that matter
Old Nov 23, 2009 | 10:09 AM
Twisted Metal's Avatar
Twisted Metal
Stuff you will need.....
MONEY
MORE MONEY
EVEN MORE MONEY
the words lift,38" Swampers,and budget don't really go together
Old Nov 23, 2009 | 11:45 AM
billywilly92's Avatar
billywilly92
Seeing that the signiature is a 99 and the truck you bought is an 01 Im assuming the sig isn't of the truck. You could get a 1 inch bigger block in the back making it a 4 inch but any more is illegal in most states.
Also its not going to be too expensive since you already have the tires but it will still be a lot if you do it correct. I would suggest doing it the correct way because having a cheap pieced together lift would be sketchy.
