Transmission woes
Old Nov 24, 2009 | 10:09 PM
slayer63b's Avatar
slayer63b
I did do a search already just not the same and cleaned the TPS already... no luck. However, I do not know the voltage to test for.So I ordered a repair manual (not Haynes).There was a leak at the Xmission cooler, which I tightened. I was going to change the fluid and filter to inspect for the obvious. Just thinking I can get a rebuilt 46e for $750 and do not want to pour money into it if its broke.
Old Nov 24, 2009 | 10:43 PM
J415's Avatar
J415
Almost everybody who did the TPS ""fix" had to replace that sensor about 2-3 months down the road. Just a heads up.
Old Nov 25, 2009 | 07:31 PM
ITTTom's Avatar
ITTTom
Cool
Here is a link you might be interested in.
merry christmas guys...
A GREAT download for and DYI Owner
Old Nov 26, 2009 | 10:10 AM
Sheriff420's Avatar
Sheriff420
the plopping into gear without a noticeable shift sounds like a busted accumulator spring. tactransman on DT would know for sure.
Old Nov 26, 2009 | 11:30 AM
Mudshack's Avatar
Mudshack
Any links to a 2nd Gen? (Pre-2001)?
Old Nov 26, 2009 | 11:59 AM
RedRigRon's Avatar
RedRigRon
Originally Posted by 004x41500
redrig, itll come faster than you think, im on here at least 4hrs a day. and you can see that i joined in august.
LOL At first I did not remember posting here, and saw what you quoted me.
It did not come out right in my head, and sounded really bad. (perverted)
With that a side and I now remember this post.... Ya WOW man, I'll get up there with you guys and let ya know.
Old Nov 26, 2009 | 12:39 PM
004x41500's Avatar
004x41500
2nd gen 1500s are 1994-2001
2nd gen 2500s/3500s are 1994-2002
Old Nov 29, 2009 | 11:34 AM
slayer63b's Avatar
slayer63b
I would not say its "plopping into gear" at all. It just downshifts when in third for a couple seconds when cruising and it only happens when it first goes into third too.
It sounds totally normal when it does it, just should not go into second because of lack of power or anything. Is there any bullitans for a firmware update on the computer consering these x-missions. Something computer related would be a easy fix.
In my past experiences keeping things updated with the newest firmware always will fix anything electronic.
Old Nov 30, 2009 | 04:50 PM
tresvatos's Avatar
tresvatos
Default 1996 ram shakes at 1, 200 RPMs
Hi everyone.. Been a while.. I have a 1996 Ram ext cab. lately when I hit 1, 200 RPMS the truck shakes until it hits 2,000 PRMs, or
I hit Overdrive, then it stops. Any ideas where to start to get this resolved?
Thanks
Old Nov 30, 2009 | 05:18 PM
xray99's Avatar
xray99
Shaking at certain RPM's could be busted belt in tires or drive train Ujoints, 2 most likely.
Probably best to start your own thread and detail the issue.
