best Primer/paint for metal
Old Nov 26, 2009 | 10:04 PM
nathangfnd's Avatar
nathangfnd
Default best Primer/paint for metal
so im going to take and get all the lose paint off my fenders and sand the rust as much as i need to and i am going to prime it to fight against rust in the future.
I got new bushwacker pocket style fender flares that i painted to match my truck but they actually look so good i dont want to put them on because the truck has scratches and dents but the flares dont but paint matches perfectly
My question to you is what would be a great primer to put on so that the rust will stop and will not someday go above the fender flares
And would it be a good idea to paint also to stop rust, I will keep the fender flares on until they break and new ones will go on right away so i really dont need it to look nice under there.
Old Nov 27, 2009 | 01:27 AM
dakotas ram's Avatar
dakotas ram
how bad is it? good chance it is all the way thru, so it will spread, but if not, por15 is a great rust stopper..... rustoleum also boasts that they prevent rust.....
partstores have some cheap products for rust, they have liquid that you brush on and it converts the rust to black primer and they also have just plain rust remover, both are fairly cheap- under $10, por 15 is a bit more......i have used the rust converter on an old truck i have about a year ago and havent painted over it yet and its doing a good job....yes, i would slap paint on also since primer is fairly poous and will absorb water
Old Nov 27, 2009 | 02:21 PM
Augiedoggy's Avatar
Augiedoggy
ditto on primer absorbing water.....I ground the rust out of the bottom of my rockers and doors and sealed and filled them with a two part epoxy..... then I primer ed it and two days later after about a two hour rain shower the rust was coming through the primer...(this was new surface rust i'm talking about.....anyway ground it back down and primed and painted it temporarily until I get around to rhinolining it like I did to the otherside ....
there is another product thats used more commercially but very similiar to por 15....call rust -zero the stuff works great but its not really ideal for the outer paint suface....Its ideal for inside panel finish and sealing as well as undercarraige and wheel wells and floor and trunk and such.
