Problems installing sure cure kit
Old Nov 28, 2009 | 12:48 PM
01Green5.9L's Avatar
01Green5.9L
Default Problems installing sure cure kit
When I lowered my servo I was very careful and paid extra attention to the accumulator and springs, or the lack there of, the accumulator balanced on the servo, I reached up and removed it and there where no springs,the other problem is that the replacement spring in the kit does not fit my accumulator,I guess the only thing I can do now is wait till Monday and see if we have a 46re trans core in the yard and get the accumulator and springs off of it.
I know for sure now that this trans was opened up and the person that did it didn't know what they where doing.
Old Nov 28, 2009 | 02:05 PM
aim4squirrels's Avatar
aim4squirrels
The replacement spring in the sure cure kit is for the 3/4 accumulator, which is under an plate in the VB, not the main accumulator on the top of the VB.
I'm sure you could stop by any trans shop and get one, or they can tell you what supplier to get them from.
Old Nov 28, 2009 | 03:08 PM
01Green5.9L
I checked online with no results,I,ll check at a trans shop monday , the only problem I had was a P1740 code so I replaced tcc&od solenoid and the sure cure, I was surprized to see no springs on the accumulator, Thanks for your reply Aim
