No power to fuel pump but power to float sensor
Old Nov 29, 2009 | 07:44 PM
amontalvo's Avatar
amontalvo
Default No power to fuel pump but power to float sensor
I have a 94 dodge ram 5.9 liter v8 2500 and the other day i was running low on gas when my truck just turned off. i figured i pushed my gas limit too much. so i put in gas as i have done before and still would not start but did turn over. replaced the fuel pump with a new one which i didnt need to to do. then after rechecking my relay fuses i realized that i did not have power to the pin 86 terminal when i turned on the ignition switch. then next thing i think is to replace the computer control module. any recommendations?
Old Nov 29, 2009 | 09:07 PM
bigred3297's Avatar
bigred3297
welcome to dodgeforum, let me move your post to your section
Old Nov 29, 2009 | 09:28 PM
silverbullet-dodgeram's Avatar
seems to me its time to chase some some wires and check for shorts and what not
Old Nov 30, 2009 | 05:52 PM
ET RAM's Avatar
ET RAM
According to the Haynes wiring diagram, the ASD and Fuel Pump relays are both fed by the same circuit. Check fuse #9 10Amp. to see if it is good. If you have voltage at pin 86 on the ASD then you have a wiring problem going to the fuel pump relay pin 86.
The wire color shown is light green/black. The PCM computer controls the ground thru pin 85 on each relay. It grounds that part to turn on the relay.
Old Jun 14, 2010 | 12:34 AM
Bristol VanSlyke's Avatar
Bristol VanSlyke
What ever happened with this!? Please reply!!
