whats with my steering?
Old Dec 8, 2009 | 10:24 PM
  #21
rideordie's Avatar
rideordie
Originally Posted by Miami_Son
I do what I can to fix those threads just so they will show up in a search, but some members complained about my efforts. Also, I find that if you put your search terms in quotes you get better results.
I for one appreciate you renaming the threads..It's extremely helpful when trying to find an answer.
+1 on putting in quotes. That helps as well.
Old Dec 9, 2009 | 03:35 PM
  #22
rafter40's Avatar
rafter40
Augiedoggy i checked it out two day. i didn't feel any play inbetween the two shafts (which would be caused by what ever is under the rubber cover correct?)
what i did feel is that with the engine off i could move the entire intermediate shaft around (a little rotating to the left and right), i looked in through the windshield and i could see the the steering wheel move. but of course the tires werent moving. is this play only because the engine was off or is this probly the source of the loose steering.
Old Dec 9, 2009 | 03:43 PM
  #23
Augiedoggy's Avatar
Augiedoggy
I believe that is normal as mine does it too...only with the engine off though
and correct their is two sections comming together under the rubber...one inside the other and mine was sloppy here..
Old Dec 10, 2009 | 04:18 PM
  #24
BigDodge99's Avatar
BigDodge99
I have a similar problem. It almost feels like the axle is moxing side to side under the truck. I have a DT trac bar and it is solid. Im starting to think it has something to do with caster.
