whining sound in motor?
Old Dec 2, 2009 | 01:16 PM
surferguy12's Avatar
surferguy12
Default whining sound in motor?
whining sound when i accelerate, i have no idea wat is but when i step on the gas it whines like a high pitch sound, wat could it be? also my oil pressure gauge is almost all the way to the red mark(the top) when i am just idling
Old Dec 2, 2009 | 07:55 PM
dodgeram07's Avatar
dodgeram07
how many miles of truck,,,,, t-chain? doe it whining at idle? does it whines in netual reving it up?
Old Dec 2, 2009 | 08:56 PM
dhvaughan's Avatar
dhvaughan
if it sounds like its coming from the passenger seat, its probably a wife or girlfriend. the best solution is to relocate that piece of equipment.
powersteering pumps can whine.
vac leaks can whistle.
alternators, waterpumps, idler pulleys, ac compressors can whine or roar.
remove the serpentine belt and rotate each pulley by hand. they should be smooth, quiet, no play, no roar, no slop.
Old Dec 2, 2009 | 10:39 PM
surferguy12
HAHAHAHAHAHA lol thats funny, but no right in the middle there is 157000 miles
Old Dec 2, 2009 | 11:00 PM
PurplDodge's Avatar
PurplDodge
I've noticed that whine in my truck too. I just ignore it.
But all the way to 60PSI at idle? What oil and filter are you using?
Old Dec 3, 2009 | 03:44 AM
rczanstke's Avatar
rczanstke
Should the oil pressure ever be that high? Mine never gets nearly that high even during heavy acceleration.
Old Dec 3, 2009 | 05:23 AM
Sheriff420's Avatar
Sheriff420
mine only hits about 45/46 psi at WOT.
Old Dec 3, 2009 | 07:35 AM
moparama's Avatar
moparama
my oil psi is wierd at cold idle its about 70psi after wrm up its about 40psi at idle. when accelerating it will go from 40psi to about 55-60psi. Is there a normal? dont seem like it ever thread i read about oil psi everyones seems to be diff.
Old Dec 3, 2009 | 08:11 AM
utahjd1's Avatar
utahjd1
My truck is Whining but I believe it's the Tranni sh**ting the bed
Old Dec 3, 2009 | 03:37 PM
PurplDodge's Avatar
PurplDodge
Yeah, that is normal. When cold, oil is very thick (This is why they tell you to warm your engine before changing the oil) and doesnt flow very well. So, at a cold start-up, the pressure will be high. Then as the motor warms up, the oil becomes thinner and can flow better. But If you are running a 10W-30 oil right now, you should change it out for some 5W-30 Synthetic oil in the winter, espcially since you live in New York.
