huge loss in performance
Old Dec 3, 2009 | 09:32 AM
01ram15005.9l's Avatar
01ram15005.9l
Default huge loss in performance
ok i got my 01 ram 1500 with the 5.9, lately its been feelin like its slacking alot i dont really know alot about engines i do body fab and paint so lookin for sum help...i read somthing about sludge buildup if you wont let truck get to working temp or somthing? idk. but its been 40- here last few weeks and i only got a few miles away to doesnt really get warmed up, but it is slacking terribly so any advise would help, thanks Cody.
Old Dec 3, 2009 | 09:55 AM
Twisted Metal's Avatar
Twisted Metal
The SEARCH feature here will help you pinpoint your problem. But the usual suspects apply, plenum leak, clogged cat, bad O2 sensors.
Old Dec 3, 2009 | 10:13 AM
GETBIG's Avatar
GETBIG
I had the same thing in my truck. new plugs change the oil add some z-max makes a huge diff you wont belive how that little stuff can change everything.
Old Dec 3, 2009 | 12:39 PM
iwhitne's Avatar
iwhitne
sea foam the motor, gastank, and brake booster... this will clean out the sludge.. do a SEARCH for SEA FOAM
Old Dec 3, 2009 | 03:40 PM
dsertdog56's Avatar
dsertdog56
Well it could one thing or a combination of things Cody, and since its an almost 9 year old truck, and I don't know how its been maintained or how many miles are on it...or what "slacking" actually means as far as performance.
But heres's the "short" list, based on your trucks age.
Tune up
Plenum leak
Timing chain
O2 sensor(s)
Tranny (slipping, shuddering)
Plugged converter
Bad gas
Map sensor
That's the short list. MAybe just spraying out the throttle body (with it wide open, motor off) and dumping some injector cleaner with de icer in it will help.
Old Dec 3, 2009 | 06:27 PM
Aubrey's Avatar
Aubrey
Or stop pickin up the fat chicks...
Old Dec 3, 2009 | 06:35 PM
Augiedoggy's Avatar
Augiedoggy
mine started stalling again today....had to keep my foot on the get for 10 mins before it would idle....
I shouldnt have said it was running great yesterday....it heard me
Old Dec 3, 2009 | 07:34 PM
seabass202's Avatar
seabass202
maybe your gas station just switched over to the winter mix fuel. I live in Florida so I don't know alot about this, but this post is typical for this time of year. I am sure that someone that knows more about winter gas than me will confirm or deny.
Old Dec 3, 2009 | 07:41 PM
Augiedoggy's Avatar
Augiedoggy
ok there too many people using the same avatar.... its confusing lol... its not the gas for me since its done this before....then cleared up like today...
Old Dec 3, 2009 | 09:07 PM
rafter40's Avatar
rafter40
augie i would check to see if the ground is making a good connection to the battery. my was doing something quite similar it sounds like. i just had to clean the ground put it back on and "wiggle" it around to make sure it had a good connection.
