what are the chances of me cracking my block
Old Dec 4, 2009 | 07:51 PM
nathangfnd's Avatar
nathangfnd
Default what are the chances of me cracking my block
I was looking online about the oil pressure issue i am having and on one of them it said that if my truck was overheating(which it was) and then you lost oil pressure(which i did soon after)then you may have cracked the block
I was driving and it was over heating(i never let it get to hot, i turned it off befor it got to high)
Then once that went away i lost oil pressure.
I replaced oil pump and oil is good but my coolant might be mixing with it. the seems to be turning black fast but i ave not run my truck for more then 5 min and my oil pressure is still zero
Old Dec 4, 2009 | 08:01 PM
95RAM360's Avatar
95RAM360
that sounds like a head gasket issue...and the Magnums do have a rep. of the Heads cracking...not the block...but if oil looks like chocolate milk/ mud then this would rlate to head/head gasket
Old Dec 4, 2009 | 10:04 PM
J415's Avatar
J415
did you ever check the sending unit like we were telling you in the other threads?
Old Dec 4, 2009 | 10:16 PM
95RAM360's Avatar
95RAM360
? previous post, is there more info in the other post
Old Dec 4, 2009 | 10:20 PM
nathangfnd's Avatar
nathangfnd
i was just wondering.
And i think im getting oil now, befor there was no exhaust smoke because it wasnt burning oil, but now there is exhaust smoke now that i replaced the pump, but no pressure(or at least it says that. i may go get a guage this weekend to read the pressure)
And the oil seems to be turning black/milky which could be from cracked block or heads and the oil and coolant mixing
Old Dec 4, 2009 | 10:22 PM
95RAM360's Avatar
95RAM360
dont run it ifthey are mixing. get it diagnosed, you dont wont to hurt it further.
Dodge.Ismo's Avatar
Dodge.Ismo
It's the head gasket or a cracked cylinder head....Dodge blocks are bullet proof.
Old Dec 4, 2009 | 10:23 PM
95RAM360's Avatar
95RAM360
^What???!!
Old Dec 4, 2009 | 10:34 PM
nathangfnd's Avatar
nathangfnd
yeah i had a few posts about what was going on with my truck about the oil with no pressure and what i did to try fix it.
I think ill check the heads in the morning, ive tried to avoid it it been like 10 degrees this week.
I have not driven it far after the new oil pump, i took it out of the garage drove it 3 houses down and backed up to the garage and its sitting there
Old Dec 5, 2009 | 12:19 AM
J415's Avatar
J415
definitely check it with a mechanical gauge before you go any further.
