factory camshaft replacement
Old Dec 5, 2009 | 05:30 PM
quackaddict's Avatar
quackaddict
Default factory camshaft replacement
Ok motor is bad in my 318 1500. So I was gonna find a used 360 and drop it in.
Got to thinking that if I could rebuild the motor I already had for not a whole lot more money I could upgrade it and have a rebuilt motor instead of just another used motor.
My question is it is cheaper if I rebuild my motor with a master kit without a camshaft and go to the 1.7 RR. My thing is if I replace the cam bearings is there a "reason" to replace the stock camshaft? I will if necessary but would save a chunk of money if the stock one will be fine because if I replace it I would probably stay with a stock one anyway as to not have to mess with the computer.
Thoughts????????????
Old Dec 5, 2009 | 06:24 PM
95RAM360's Avatar
95RAM360
IMHO i would get a 360 and build that up, theres WAY more options for the 360 over the 318. is the 318 running still? or is it completly gone? i was gunna say if you can make the motor last you a lttle lnger id get the 360 and build that.
http://car-part.com
this is the best place for getting the parts you need...in my opinion
Old Dec 5, 2009 | 06:58 PM
quackaddict
thanks boss, the heads I was gonna get a good deal was for an 88 model and I have an 01 so I think I am gonna build up a 360.
Old Dec 5, 2009 | 07:31 PM
95RAM360's Avatar
95RAM360
that would be the best bet, like i said you will find way more stuff for a 360...im in the process of building mine up now, but its my DD so im doing little parts at a time.
Old Dec 5, 2009 | 07:52 PM
quackaddict
yeah it is just getting confusing as to if I want to build it up or just drop it in rebuild my 318 or what. This is a project truck so I got plenty of time just trying not to get discouraged.
Old Dec 5, 2009 | 08:45 PM
95RAM360's Avatar
95RAM360
you wont be able to get a 318 up to the potential of a 360, but if you do a 318 rebuild, get a stroker kit for it.
Old Dec 5, 2009 | 11:05 PM
BlueBeast2's Avatar
BlueBeast2
a set of 88 heads won't work on an 01 i don't think. No matter what you do its gonna cost money. trying to be "cheap" never lasts when rebuilding an engine trust me
Old Dec 5, 2009 | 11:12 PM
halfamil's Avatar
halfamil
Why is your 318 bad? Did it blow up? Might be a cheap fix for it.
Old Dec 6, 2009 | 01:54 PM
quackaddict
Well I am not trying to be "cheap" for sure, but best bang for the buck is completly different.
Engine needs a rebuild so I am trying to decide if I am just gonna drop in a used 360 or get a 360 and build up a little or just rebuild the 318. Leaning towards getting a good running used 360 and beefing it up a little..............or I found an 8.0 488 I could try and cram in there?????????????
Old Dec 6, 2009 | 02:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Among other things, the 8.0 will not bolt up to your existing tranny.
