new to me 2001 1500
Old Dec 9, 2009 | 10:09 AM
coreyt's Avatar
coreyt
Talking new to me 2001 1500
Hello all.
New owning a dodge. Really like the truck. Just have a few questions.
This is what I have found out so far.
1. I need to look at the plenum gasket, either with the FSB or with a mirror through the intake.
2. the front O2 sensor will probably need to be replaced.
I have replaced the heater core and the passenger side ball joints and both front axle u-joints.
Is there anything else that I should look at?
Thanks for you help in adavance.
Old Dec 9, 2009 | 11:11 AM
halfamil's Avatar
halfamil
How does it run and drive?
Old Dec 9, 2009 | 01:31 PM
95RAM360's Avatar
95RAM360
check the tranny fluid. (when running in neutral. a reading from park WILL NOT be accurate) see if it has a burnt smell, or if its low.
Old Dec 9, 2009 | 09:18 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by coreyt
New owning a dodge.
HA-HA.
welcome to df. fill out your signature.
let's see, all you're likely to need is -
timing chain
water pump
front crank seal
rear main seal
IAC
TPS
check valves
serpentine belt
front wheel bearings.
front axle seals
track bar
ball joints
speed sensor
brakes
rear drive shaft u-joints
shocks
transmission.
steering shaft
steering box
clean or replace headlights.
replace CAD with Posilok
head, amp, speakers
replace cat
tune up, wires, plugs, rotor, cap
any more leaks - oil pan, valve covers.
t-stat.
transmission cooler
dash
that ought to do it.
Old Dec 9, 2009 | 09:24 PM
95RAM360's Avatar
95RAM360
^LMAO
he nailed it
Old Dec 9, 2009 | 09:43 PM
moparama's Avatar
moparama
Right on the money
Old Dec 9, 2009 | 09:52 PM
J415's Avatar
J415
Originally Posted by dhvaughan
HA-HA.
timing chain
water pump
front crank seal
rear main seal
IAC
TPS
check valves
serpentine belt
front axle seals
track bar
ball joints
speed sensor
brakes
shocks
transmission.
steering shaft
steering box
head, amp, speakers
replace cat
t-stat.
transmission cooler
dash
How could you forget about the freeze plugs!!!
Old Dec 9, 2009 | 09:54 PM
PurplDodge's Avatar
PurplDodge
HA-HA.
timing chain
water pump
front crank seal
rear main seal
IAC
TPS
check valves
serpentine belt
front axle seals
track bar
ball joints
speed sensor
brakes
shocks
transmission.
steering shaft
steering box
head, amp, speakers
replace cat
t-stat.
transmission cooler
dash
Thats pretty consistant with any used truck. So dont be scared.
Old Dec 10, 2009 | 11:02 AM
coreyt's Avatar
coreyt
Not to worried at all. Have rebuilt entire trucks before. Just wanted to have some opinions on what is needed.
I did read a thread about how to check your CAT, but now I can't seem to find it. I thad some temps for inlet and outlet in it.
Full tune up is in the works. Already had the tranny looked at and flushed.
and the dash is in great shape. not cracks.
Old Dec 10, 2009 | 11:08 AM
J415's Avatar
J415
...just wait. It won't be long.
