Lift block help
Old Dec 10, 2009 | 12:59 PM
rwilhelms's Avatar
rwilhelms
Default Lift block help
So im gonna put a lift in and im planning on putting a 3inch coils spacer in front and blocks in the back. So I've herd some bad things about stacking blocks and I was wondering if I would be better off getting 5inch blocks an taking out the factory ones that are installed now.
Old Dec 10, 2009 | 02:25 PM
95MaroonMonster's Avatar
95MaroonMonster
yep, ditch the factory blocks
or keep it and get an AAL
Old Dec 10, 2009 | 09:21 PM
codyselcamino's Avatar
codyselcamino
lift blocks are scary anyways, if you go with big lift blocks you will have wheel hop from hell!
Old Dec 11, 2009 | 05:10 PM
rwilhelms's Avatar
rwilhelms
so how hard are aal to put in do they just slide under the stock leave pack or do you have to take the leafs apart and put it in the pack. Cause I dont have the tools to do this.
Old Dec 11, 2009 | 08:26 PM
95RAM360's Avatar
95RAM360
im not sure, but can you get longer shackles to get a lift out of it? cuz i changed my shackles not to long ago and it only takes about 25 minutes to do them (each side)
Old Dec 11, 2009 | 08:40 PM
codyselcamino
longer shackles will lower it, shorter ones will work though, but less suspension travel
Old Dec 11, 2009 | 09:23 PM
lord0fsal3m's Avatar
lord0fsal3m
im considering add a leafs, you can get skyjackers on ebay for around $90
