Pfft Easy as Pie
Old Apr 14, 2005 | 06:35 PM
crusher135's Avatar
crusher135
Default Pfft Easy as Pie
If u ever break a control arm never and i repeat never take it to a mechanic shop damnit, go buy the peice and put it in urself its 2 bolts just make sure if its a lower control arm u mark where the cam sits :P it was so easy to replace my upper and lower control arms since i bought aftermarket ones so easy
Old Apr 14, 2005 | 06:47 PM
steve05ram360's Avatar
steve05ram360
Default RE: Pfft Easy as Pie
I swapped the bushings out on my stock ones for the urethane ones, it was a bitch getting them back in because of the bushing but well worth the effort. hardest part was pressing out the old bushing and cleaning it up (I used a home made press tool).
Old Apr 14, 2005 | 07:10 PM
crusher135's Avatar
crusher135
yeah, i broke my lower control. arm from a big *** rock :P so i had to repolace it but i decided to go with some aftermarket stronger ones so it will never happen again and it comes with the new bushings and stuff its very easy to do its like 2 bolts for lower 2 bolts for top and ur done not too hard :P the cam is a little tricky to adjust again but i put it almost where it was before but now it seems like my alligment is better lol
Old Apr 14, 2005 | 09:48 PM
steve05ram360
which arms did you get? any link to a website?
Old Apr 15, 2005 | 09:43 PM
crusher135's Avatar
crusher135
Bds arms http://www.bds-suspension.com/pdfs/122302.pdf they dont have the right uppder and lower link kit in a picture form so theres the installation thing :P the lower arms on that website are different then the ones i got
