97 ram, 5 speed wont shift into gears?
Old Dec 16, 2009 | 08:46 PM
cbrcolt45's Avatar
cbrcolt45
Thanks its downloading now, silver... the truck will shift fine without clutch, how would i adjust it? sorry i just dont know anything about these trucks.
Old Dec 16, 2009 | 10:21 PM
cbrcolt45's Avatar
cbrcolt45
Update..... Still have the problem, im still trying to figure out how to check the master cylinder, or even where it is, the clutch fluid seems to be all the way full, is it possible the lines could be clogged or something?
Nothing seems to be leaking either.
Old Dec 16, 2009 | 10:24 PM
Bubba39047's Avatar
Bubba39047
i've got the nv3500 5pd to and i notice every once in a while it doesnt like to go into first. what i do is just put her in N and let off the clutch. pump it a few times and it'll go in after that. 2nd has done it once or twice. no grinding. so idk. maybe it just wasn't taken care of? how many miles? was it used for trailers alot?
Old Dec 16, 2009 | 10:27 PM
cbrcolt45's Avatar
cbrcolt45
150k miles, seems that someone took care of it, just had new clutch also, i try to pump the clutch and everything, I keep thinking the fluid isnt getting there or the master is bad....
Old Dec 16, 2009 | 10:33 PM
Bubba39047's Avatar
Bubba39047
well that would sound about right. mine has 73k miles. so yeah. the nv3500 tranny is a good one no doubt, im sure its somethin simple that causes problems.
Old Dec 16, 2009 | 10:36 PM
cbrcolt45's Avatar
cbrcolt45
Well thanks a lot, im taking it to a shop tomorrow, ill update it then.
Old Dec 16, 2009 | 10:39 PM
Bubba39047's Avatar
Bubba39047
good. be sure to. how bout some pictures soon of this ram that seems to be givin you more troubles than a chicken on crack? (ive noticed your other thread bout the error lights)
Old Dec 16, 2009 | 10:57 PM
cbrcolt45's Avatar
cbrcolt45
UPDATE!! Ok i feel pretty dumb now, i have been looking at the brake parts under the hood instead of the clutch, i just figured out where the clutch parts are... On the inside of the truck, Im guessing the master cylinder.. Appears that at one time this was leaking... but the reservoir is full, so would it be right to say its the cylinder thats bad? anyone know how much these can run?
Old Dec 16, 2009 | 11:03 PM
Bubba39047's Avatar
Bubba39047
I dont imagine it being to much but look at it this way, if that is the only problem then youhave to get it fixed to drive the truck without being scared to go below 3rd gear. lol. just take her to the shop.
Old Dec 16, 2009 | 11:14 PM
cbrcolt45's Avatar
cbrcolt45
yea im not messing with it, going to the shop, thanks a lot!!
