Trans problems! Help me please
Old Dec 17, 2009 | 12:48 PM
brdarren's Avatar
brdarren
Default Trans problems! Help me please
ok so i have a 2001 dodge ram v10 with automatic trans and the trans is starting in 2nd gear any ideas as to why it would do this. there are no codes and the fluid and filter are fresh.
Old Dec 17, 2009 | 01:04 PM
jbomb's Avatar
jbomb
do some more checking but I think that can be caused by your governor malfunctoning, or your overrunning clutch is slipping. Check your linkage first tho. Because its easy and quick and free.
Old Dec 17, 2009 | 04:17 PM
95RAM360's Avatar
95RAM360
can you get it in first with the column shifter?
Old Dec 18, 2009 | 12:04 AM
brdarren's Avatar
brdarren
yeah it takes off BEAUTIFLY when i manually shift it into first on the column!
