Aftermarket Headlights Not Working!
Old Dec 18, 2009 | 08:46 PM
1994dodgeramguy's Avatar
1994dodgeramguy
Default Aftermarket Headlights Not Working!
I installed some halo projector beam headlights in my 1994 dodge ram. they worked great for 2 months. no issues what so ever. then they just stopped working. the running lights still turn on as do the instrument panel lights. I've replaced the headlight switch, the dimmer switch, the fusible link in the engine bay, and a fusible link i found under the dash that looked as though it went to the switch. nothing has worked and i'm very very frustrated. can anyone help me out?
Old Dec 24, 2009 | 12:25 AM
hydrashocker's Avatar
hydrashocker
You are in a dead area and you need to post in your era of year of make.
2nd Gen Ram
1994 through 2001 Rams
~Rustin~
Old Dec 24, 2009 | 01:39 PM
Trey318's Avatar
Trey318
Did you check the bulbs? Maybe you got moisture in them?
Old Dec 24, 2009 | 06:46 PM
Augiedoggy's Avatar
Augiedoggy
ok theres nothing to fail but the power to the bulbs or the bulbs themselves....did you do any rewiring? maybe something has shorted? did you try the high beams?...if nothing works id say its before the lights...use a cheap light tester or multimeter to see if there is even power going to them.....if they are the same halo style lights I have you had to rewire them to use on non sports so maybe thats where the problem lies...try a bulb they are $5.99 at advance auto if you have one...I believe my halos take H7 style bulbs... I had a faulty one when mine where new that would short against the housing replaced it and all has been fine since..
