Plenum Gasket Replacement
I got all of the gaskets from the Dodge dealer. The pan itself is stainless steel I believe, not sure. I just buffed all the carbon deposits off it and reused the same pan. Hopefully, all will continue to go well. Good luck on the head swap, if you haven't already done it!
