bypass 02 sensors?
Old Dec 24, 2009 | 11:57 PM
johnjokela's Avatar
johnjokela
Default bypass 02 sensors?
if you have a bad o2 sensor could you just use the "non foulers" trick to bypass it out of the way, or when they go bad their bad? and is that all the pcm reads is a constent bad signal???just a random thought, i have a cali truck with 4 sensors and those arent that cheap when i have to replace them.
Old Dec 25, 2009 | 12:14 AM
PurplDodge's Avatar
PurplDodge
Which ones are bad?
Old Dec 25, 2009 | 12:41 AM
johnjokela's Avatar
johnjokela
none are bad "yet" just a thought
Old Dec 25, 2009 | 12:53 AM
dakotas ram's Avatar
dakotas ram
your aftercat ones can be tricked
Old Dec 25, 2009 | 01:34 AM
PurplDodge's Avatar
PurplDodge
Yeah, you cannot "trick" the pre-cat sensors because those are used by the computer to determine the air/fuel ratio.
Old Dec 25, 2009 | 09:45 AM
clipper77's Avatar
clipper77
How would you go about "tricking" them?
Old Dec 25, 2009 | 01:38 PM
dakotas ram
ONLY for the after cat
https://dodgeforum.com/forum/2nd-gen...ving-cats.html
Old Dec 26, 2009 | 04:38 PM
clipper77's Avatar
clipper77
Good info, thank you.
