noisy rear end/speedometer not working
Old Dec 27, 2009 | 01:21 PM
ssmith2042's Avatar
ssmith2042
Exclamation noisy rear end/speedometer not working
OMG! I have a 2000 dodge ram 1500 4x4 1/2 ton. I have reaplced the rear differential everything but the pinon, (the diff case, clutch, bearings).
While taking off the brake drums, I cracked them . Replaced those and the spedometer wasn't working. Replaced Speed Sensor.
Noise still there and spedometer still not working.
What's Nex????????
Old Dec 27, 2009 | 02:56 PM
2001Ram's Avatar
2001Ram
So the speedo stoped working after the brake problem? If its always been bad check the speedo gear.
Old Dec 27, 2009 | 03:37 PM
dakotas ram's Avatar
dakotas ram
what kind of noise also?
Old Dec 27, 2009 | 04:46 PM
Miami_Son's Avatar
Miami_Son
Speedometer.
Old Dec 28, 2009 | 08:13 PM
ssmith2042's Avatar
ssmith2042
It is a whining/vibration sound. It get worse the faster you go.
Old Dec 28, 2009 | 08:14 PM
ssmith2042's Avatar
ssmith2042
Sorry, yes your correct. Speedometer. Still not working after replacing the speed sensor.
Old Dec 28, 2009 | 08:28 PM
Augiedoggy's Avatar
Augiedoggy
did the noise start all at once and after you did the work?....normally whining noise could be a bad bearing or incorrectly seated or damaged gears...
Old Dec 29, 2009 | 11:03 PM
Dakine69302's Avatar
Dakine69302
you should have speedo sensors, one in the tranny and one in the rear diff, check both of those
Old Dec 30, 2009 | 10:15 AM
ssmith2042's Avatar
ssmith2042
Hey thanks. I took it over to the shop and they said the fron u joints need replaced and my husband didn't set the rear differential back up correctly so they are going to fix it for another $600.
Happy New year to me
Old Dec 30, 2009 | 10:16 AM
ssmith2042's Avatar
ssmith2042
My husband said he replaced the one on the tranny, I'll let him know that there is one on the rear diff too. Thanks so much.
