Won't start
Old Jan 3, 2010 | 04:41 PM
CentralOregonian's Avatar
CentralOregonian
Default Won't start
2000 Dodge Ram Cummins 2500, 4 WD, Automatic. Turns over but won't start. Relays & Fuses okay. Shifting linkage okay. Replaced neutral safety switch. Fuel is delivered to the injectors. The only obvious issue is that the steering wheel does not lock when the key is removed. How is this fixed or is there something else causing the problem??
