Parking lights and instrument panel
Old Jan 5, 2010 | 08:50 PM
ram-bo5252's Avatar
ram-bo5252
Default Parking lights and instrument panel
i need some help on an issue im having with my parking lights and instrument panel. Neither one will work! are these two on the same fuse? if so, which one? all the fuses checked out fine. Any help would be appreciated
Old Jan 5, 2010 | 08:53 PM
ram-bo5252's Avatar
ram-bo5252
oh sorry, it is a 1995 Ram 1500..
Old Jan 5, 2010 | 09:02 PM
95RAM360's Avatar
95RAM360
theres two fuse boses, check them both, check the wiring as well.
Old Jan 5, 2010 | 09:16 PM
halfamil's Avatar
halfamil
Headlight switch is going bad.
Old Jan 5, 2010 | 09:35 PM
Keegan's Avatar
Keegan
I just had the EXACT SAME problem on the weekend.
Check your tail lamp fuse. If it's blown, replace it. If it blows again, you have a short. Mine happened to be within a 12inch section of the harness where it goes through the firewall to the white bulkhead connector under the dash. Ended up soldering a new piece of wire going from the bulkhead to the connector under the drivers side cab, behind the front left fender.
The shorted wire I had was black w yellow stripe, better known as the running light / park light wire. What a mess wiring can be. One sure way to tell if you have a short aside from a blown fuse is to hook up a multimeter and measure resistance on that wire.
Old Jan 6, 2010 | 07:33 AM
ram-bo5252's Avatar
ram-bo5252
thanks for all the quick responses!! ill be working on all that today!! Thanks again!
