Crazy electrical issues
Old Jan 6, 2010 | 10:19 AM
RonRacer's Avatar
RonRacer
Default Crazy electrical issues
ok so i've been having some problems cranking my 1500 up. 1st i changed the neutral safety switch and that worked for awhile, then i bought a new starter and starter relay. but now its happening again with extra symptoms. when i go to crank the truck up i turn the key and nothing happens. seeing that this is my DD now i have to jump the starter with a hotwire to the relay contacts in the fusebox. the new symptoms are my windows dont roll down, my heat/ac doesnt blow at all, and my speedo isnt working....... suggestions anyone??
Old Jan 6, 2010 | 10:49 AM
95RAM360's Avatar
95RAM360
its a ground, im 95% sure its a measly ground.
i had an electrical issue where i had no brake light, but had third brake light, no reverse lights, when i hit the left blinker the reverse lights would flash, when i hit the hazards, they'd flash on the dash but not the lights themselves. and it was all becuase of 1 ground wire.
