97 2500 Tire question 4x4
Old Jan 9, 2010 | 02:22 PM
mike330's Avatar
mike330
Default 97 2500 Tire question 4x4
Im picking up a ram 2500 this weak and will be used as a third veh. Will 35s fit without a lift?
It will be strictly a on road veh. Or can I get away with a 2 in leveling kit?
Old Jan 9, 2010 | 04:21 PM
95RAM360's Avatar
95RAM360
i believe the highest you can go is 33's on the 2500's, the 35's will fit the rear, but wont up front....33's rub the bumper when turned all the way on 1500 4x4's. but with a 2 1'2 leveling kit, and take out the stock 2in. block in the rear to put a 3in, and that should be perfect.....and hopfully you have the 3.92 gears, you will have horrible performance with 35's if you have 3.55 gears
