Truck problems help please
Old Jan 14, 2010 | 05:49 PM
Moparfanatic91's Avatar
Moparfanatic91
Default Truck problems help please
Hey guys ok so I've got a bombshell tht just hit my 1997 dodge ram 1500 within a week so here's the list. If possible could you answer them with as much detailed info as possible.
1. Tranny when put into reverse makes a whine/humming noise then goes away(hasn't done it recently)
2. The green back light for the dash doesn't work when I turn my headlights on and it's not dimmed....
3. Brake lights don't show when I have my headlights on until I press on the brakes
4. Fog lights do not work at all
The last 3 happened at the sametime and idk where to start. Any help will be appreciated thank you
Old Jan 14, 2010 | 05:52 PM
95RAM360's Avatar
95RAM360
1. when was the last fluid/filter change? hows the fluid level/smell?
2,3,4. could all be related, could be a ground wire, which i think is your problem, or a blown fuse
Old Jan 14, 2010 | 06:01 PM
dhvaughan's Avatar
dhvaughan
i'd look into the headlight switch first for all the electrical problems. its a common failure.
i assume you already check tail light bulbs and fuses, both in the end of dash and under the hood in the pdc.
transmission pump makes a little groaning sound when cold in reverse. pretty normal and nothing to worry about unless it starts doing something worse.
