Did u know K&N made oil filter too? lol
Old Apr 19, 2005 | 09:01 PM
zeekxxx's Avatar
zeekxxx
Default Did u know K&N made oil filter too? lol
Thats too funny here is what they say - cut and pasted -
Sorry to sound like an ad but I thought this might be worth trying.. Anybody got an opinion....
K&N Performance Gold® Oil Filters
Originally developed for demanding race applications, our premium oil filter is rapidly becoming a favorite among consumers for its durability and easy removal. We’ve changed oil filters and several of our product development technicians are sportsman class drag racers. They insisted we offer an oil filter that corrected the “headaches” they experienced over the years changing oil filters.
Our Oil Filters Have Nuts
We have all been there: Whether it’s remembering where that disappearing canister tool is; or having oil leak all over your garage and yourself; or finally giving up and pounding a screwdriver through the filter just to get if off. Each of our automotive and marine oil filters comes with a 1” nut welded to the top of the canister so they can be easily wrenched-off with a standard tool. Our motorcycle and ATV oil filters come with a 17 mm nut.
Heavy-Duty Construction for Extreme Conditions
To satisfy the demands of racers, our oil filter has many features over and above the requirements of most vehicles. We use thicker canister walls for extra strength and durability which reduces the risk of damage from loose rocks and debris. The heavy-duty construction will withstand higher oil pressures found only in racing environments without bursting. The drilled hole on the nut is for a safety wire attachment. Required for many types of racing, the safety wire prevents blown oil filters from falling on the track and representing a hazard to other race vehicles. This extra engineering offers piece of mind for consumers who want only the best.
High-Flow Rate
Our oil filters use resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration. High filter flow rates are important in racing vehicles where heavier grade oil is used and the oil is pumped much faster than in a standard vehicle. When the engine is circulating oil at high GPM rates, the high-flow oil filter helps reduce the loss of pressure through the filtering process.
Compatible with the Latest in Synthetic Engine Oils
Our oil filters are ideal for high-end synthetic motor oil. Synthetic motor oil is said to offer improved flow performance at cold temperatures while providing superior protection against thermal degradation.
Warranty
Our oil filters are covered by a limited warranty to be free from defects in materials and workmanship when installed and replaced using engine and equipment manufacturers recommended service intervals.
TECH TALK
Our Performance Gold Oil Filters use a cellulose media bound by phenolic resin surrounding a metal inner core that provides structural strength to reduce the risk of filter collapse. The resin is the "glue" that holds the media fibers together and at the same time keeps "pores" open by keeping the fibers apart. The resin is cured to full strength during the element manufacturing process. Phenolic resin systems are an excellent choice for the high temperature demands of oil filters. Our filter includes an anti-drainback valve, when applicable, that prevents oil from draining back into the crankcase during engine shutdown. The anti-drainback valve is useful in situations where the filter is mounted horizontally which could allow backflow. We use rolled threads to help prevent stripping during installation or removal and an internally lubricated gasket provides a positive seal even after the filter has been removed and reinstalled.
Old Apr 20, 2005 | 01:00 AM
RAMDAN1500's Avatar
RAMDAN1500
Default RE: Did u know K&N made oil filter too? lol
yes i did, infact its the only filter that i used on my previous VW! but now i get free mopar filters!
Old Apr 24, 2005 | 05:02 PM
tehdago's Avatar
tehdago
They are actually great filters. I use them whenever I can't get my hand on WIX filters locally.
