Ram 2500 Running Bad
Old Jan 18, 2010 | 08:05 PM
smitty9306's Avatar
smitty9306
Thanks zman17 I plan on doing the plenum with the hughes kit. Even though it doesnt look like it is leaking. The cat was original cat and was falling apart and rattling. I just don't trust the gasket on it after reading about it on the forum. I checked down in the intake for oil and there is none. But that is beside the point i want to get it changed before I have a problem with it. Any more problems with it and Ill punch the cat out as there is no echeck around here. Could someone point me to where I can find the hughes intake please?
Thanks
Jon
Old Jan 18, 2010 | 08:07 PM
95RAM360's Avatar
95RAM360
even though there is no oil, there will be. EVERY 3.9/5.2/5.9 magnum engine will have this problem
its a pretty easy job...ive done it twice, first time i forgot to put new o-rings on injectors, and they leaked...note: you do not have to remove fuel rail/fuel injectors when doing plenum
and i was off one on each prong on the cap so it misfired. The second time i did it, it was a breeze with no problems.(i did it again because i got a kegger intake from m boss' 5.2 and i got it port and polished and kegger modded. first time i put it back in full of oil/no kegger mod.
if your an average backyard mechanic you can do it. no special took except torque wrench and fuel line disconnect.
Old Jan 18, 2010 | 08:19 PM
smitty9306's Avatar
smitty9306
yes I agree entirely I am going to replace it asap. Just need to locate a better plenum gasket than the stock ones I don't want to change it every 3 months.
Thanks
Jon
Old Jan 18, 2010 | 08:31 PM
smitty9306's Avatar
smitty9306
I found the Hughes site. Should have googled it before I asked I will order it tonight.
Thanks Again Guys
Jon
Old Jan 18, 2010 | 08:39 PM
RicksterB's Avatar
RicksterB
Grab a 180 degree thermostat while you're there.
Old Jan 18, 2010 | 08:46 PM
95RAM360's Avatar
95RAM360
yea, and get the intake gaskets w/ bolts from hughes as well. the intake bolts are TTY (torque to yeild)
Old Jan 19, 2010 | 07:29 AM
zman17's Avatar
zman17
Retired Moderator - RIP
He lives in Baltimore, forget the 180 stat. Use the stock replacement. 195
