360 engine help!
Old Jan 19, 2010 | 09:00 PM
01ram15005.9l's Avatar
01ram15005.9l
Default 360 engine help!
ok guys i got my 01 ram with 360, today i put in some chevron injector cleaner cuz i had alot of friends recommend it to me. and a few days ago i got a new alternator and belt idk if thats the problem but, today after putting in cleaner i took it out to run it through a little and i was noticing a change within 15 minutes or so. So i decided to get on it a little bit and ended up racin a few people and now theres a decently loud ticking noise coming from what sounds to be inside the engine...idk what in the world it is but i really need it to be somthing simple...sounds like a little tick and can hear it very well with hood open, i really have no clue i dont know much about engine im a body fab guy thats why i joined these forums! so please helm or give me some suggestions thanks, cody.
Old Jan 19, 2010 | 09:29 PM
dodgeram07's Avatar
dodgeram07
problem or lifters or rockers making the ticking..... so does it sound like it in the middle of the motor or just under the vavle covers?
Old Jan 19, 2010 | 09:35 PM
01ram15005.9l
i dont know for sure but id say smack in the middle...i mean cuz i can here it same loudness on both sides....and louder if im just in the middle so..
Old Jan 19, 2010 | 09:37 PM
halfamil's Avatar
halfamil
Could be a lifter, exhaust leak, wire arc, timing gear, rocker arm, etc. It's very hard to tell from here. How many is a few races, and how hard, and long did you run it.
Old Jan 19, 2010 | 09:39 PM
01ram15005.9l
uhm two races, one with a stang lasted till around 60 to the floor, and other was with some jettas that one was too the floor till 100 or 105
halfamil's Avatar
halfamil
Could also be a pulley.
Old Jan 19, 2010 | 09:48 PM
01ram15005.9l
idk but you think the injector cleaner could be causin it? i know i had a ton of engine sludge and ****.....
Old Jan 19, 2010 | 09:50 PM
PurplDodge's Avatar
PurplDodge
Dont street race. Simple as that.
Doe it only tick under load? If so, its just pinging and your Chevron cleaner is doing its job, cleaning carbon.
Old Jan 19, 2010 | 09:53 PM
01ram15005.9l
it does it at a steady knock..knock...knock exact timing apart...and idk if it does it while driving my exhaust is to loud but idling is where i started to hear it...also i didnt fill up after usin cleaner i put it in with little under half and didnt fill it back up.
Old Jan 19, 2010 | 09:55 PM
91xjgawes's Avatar
91xjgawes
lifter....
