front speaker wiring
Old Apr 20, 2005 | 04:36 PM
krams05's Avatar
krams05
Default front speaker wiring
I am trying to put different speakers in the front. The stock front ones have an amp attached that I need to take off b/c I am going to amp them with a separate amp. Has anyone done this before that they know what to do, by means of what wires to use, or if I am going to have to run all new speaker wire to the speakers. Any help or suggestions would be greatly appreciated.
Old Apr 21, 2005 | 06:38 AM
waterbug1999's Avatar
waterbug1999
Default RE: front speaker wiring
HUH? If your swapping speakers and amp, just undo the wires from the old one and put them on the new amp.. Or am i reading this wrong?
Old Apr 22, 2005 | 12:59 PM
moparmania's Avatar
moparmania
the best way is to bibass all stock speaker and amp wires and run new when dealing with a rig that has the factory amps installed. you will use better wires with more shielding to handle higher power outputs.
Old Apr 22, 2005 | 01:20 PM
krams05's Avatar
krams05
It sounds like you have done this before, so thanks for the tip. I will give it a try. Do you know is there a way to do it without running new wire? Thanks.
Old May 12, 2005 | 04:42 PM
Tani1500's Avatar
Tani1500
I just changed my speakers about a few weeks ago. what kind of speakers are you getting. I dont think mine had an amp aready on it. i have a friend who hooks up amps for a living. maybe he can help you out. ill ask him.
