I think the jet fuel kinda did a seafoam to his engine allready...
Check you're oil level anyway..
and do a compression test..
I'd say you smoked the rings, warped a head, seized a bearing,at the least. Jet fuel burns HOT The oily smoke may not have been blue at those temps.
i agree, smoked rings especially. stock rings and pistons are gonna have a REAL hard time with that kinda heat
can you really say that you wouldn't have tried that when you were a teenager, given the opportunity? I woulda probably tried it myself if I had easy access to the fuel
I put about 5 bottles of octane booster in my old sled when I was younger, headed out on a poker run and got about 10 miles before I burnt a hole through a piston the size of my finger.
