What are your gauges at?
Old Jan 22, 2010 | 04:06 PM
95RAM360's Avatar
95RAM360
Default What are your gauges at?
ok, i just want to see what the average gauge reads are for people...
this is mine
RPMS-
-idle in park, 700 rpms
-idle in drive, 500 rpms
-Catches at about 1100 rpms
OIL-
-Idle 45-50
-Running 55-60
VOLTS-
-16.5
TEMP-
-195 always
just thought it would be interesting to see how different rams run.
Old Jan 22, 2010 | 10:55 PM
Skab's Avatar
Skab
RPMS-
-idle in park, 650rpms
-Catches at about 1100 rpms??
OIL-
-Idle 20-50
-Running 30-50
VOLTS-
-16.5
TEMP-
-180 steady
Old Jan 22, 2010 | 11:32 PM
yakkier's Avatar
yakkier
Idles around 900, idle in drive around 1000, holds at around 1200
oil, idles at 40 running around 45
15v
temp after warm up 210 on the nose
sit22 II's Avatar
sit22 II
FUEL-
empty
Old Jan 23, 2010 | 12:21 AM
dakotas ram's Avatar
dakotas ram
hehehe
Old Jan 23, 2010 | 12:22 AM
yakkier's Avatar
yakkier
What ? did you finally look in the mirror ? HA!
Old Jan 26, 2010 | 10:15 PM
TheGreatDrake's Avatar
TheGreatDrake
RPM's
idle at 700ish in park when working correctly otherwise it seems to get stuck at around 2k-3k in park while throwing a p0505 code (iac circuit problem supposedly)
in drive its 600 unless said problem occurs then it hangs at 1.5k-2k in drive
oil is always just under 40 i'd say around 35 maybe
voltage sits at 14.8- 15
temp stays around 180-190
