Installing new fog lights today
Old Jan 23, 2010 | 11:57 PM
Ram_Me's Avatar
Ram_Me
Rewire the headlights with a better than stock headlight harness. That will definitely help your lights out.
Old Jan 24, 2010 | 08:02 AM
Sheriff420's Avatar
Sheriff420
you had better throw some paint on the ground wires before they rust out on ya.
i like that switch too, the knee blocker is a good spot for switches.
and from the looks of it, those lights will fit in the bumper it you open up the holes a little bit like i did on my dads truck.
get a cutting wheel made for cutting plastic
draw a line so you get a straight cut, i used a tooth pick to keep it straight.
cut it out
bolt on any old piece of steel that will line up with the hole in your bumper so your lights will be centered in the holes.
then adjust them so they're pointing straight and you're done.
Old Jan 24, 2010 | 09:17 AM
fatchance82's Avatar
fatchance82
I too have tried "restoring" my headlights with little success.
Old Jan 24, 2010 | 09:54 AM
WaynesWorld's Avatar
WaynesWorld
I did what sheriff did to his dads. Opened up the holes, fabbed up some brackets and mounted in the factory locations.
Old Jan 26, 2010 | 12:56 AM
iwhitne's Avatar
iwhitne
get some aftermarket headlights.... $125 on ebay.. well worth it!
I need to re mount my lights because they were starting to break the mesh on my bumper to crack.. so i need to remount and rewire them and also finish my center console
