have 2 questions regarding my brakes and tranny
Old Jan 29, 2010 | 10:12 AM
jtheshowstoppper's Avatar
jtheshowstoppper
Default have 2 questions regarding my brakes and tranny
im kinda new here and this is my first dodge truck its a 98 5inlift and 3inch body lift on 39.5 superswampers with 20in rims are there any cheap brake upgrades i can do?like junk yard swap from a 2500?and my other question is my tranny sometimes when i put it in reverse then go to drive it does nothing sounds likes its stuck in nuetral unless i put in park turn it off and turn it back it shifts perfectly any help greatly appreciated
Old Jan 29, 2010 | 10:20 AM
Aubrey's Avatar
Aubrey
You didn't give much info on it. This is a 1500?
You need to have it serviced. It could be a lot of things (too little/too much fluid, misadjusted linkage, something internal, etc).
Mowhawk's Avatar
Mowhawk
You can do a full drum to disk conversion. Upgrade your front disks to 2500 or 3500 ones. Upgrade your rear drums to the chevy 3500 ones of same year ( i think its same year).
Old Jan 29, 2010 | 10:37 AM
jtheshowstoppper
yes its a 1500 with the 5.9
Old Jan 29, 2010 | 10:38 AM
jtheshowstoppper
will the 2500 just bolt up?
Old Jan 29, 2010 | 03:04 PM
J415's Avatar
J415
what about the 1 ton wheel cylinder upgrade? Also you can put dual piston calipers from an '01 on your truck. Of course, as purpl always reminds us, you'll have to put the knuckles on there as well.
Old Jan 29, 2010 | 03:16 PM
Mowhawk's Avatar
Mowhawk
yes sir
Old Jan 29, 2010 | 03:19 PM
Aubrey's Avatar
Aubrey
Mowhawk, you should define 'just bolt up'. They are different axles. It is not a matter of pulling off your old calipers and putting on calipers from a 2500 or 3500.
Old Jan 29, 2010 | 03:26 PM
Mowhawk's Avatar
Mowhawk
The rotors are bolt up. Theyre still five lug, for the 2500. Im looking at them right now
Old Jan 29, 2010 | 03:35 PM
Aubrey's Avatar
Aubrey
I do not believe that is correct. A 3500 is an 8 lug. A 2500 (maybe depending on motor) is also an 8 lug. It will not go onto a 5 lug 1500.
