wheels leaning in/out
Old Jan 30, 2010 | 05:14 PM
Augiedoggy's Avatar
Augiedoggy
could be your alignment is off so much its effecting your camber as the wheels walk apart or closer together...one of my golf carts has thes issue and reverse they go the opposite angle as forward...
Old Jan 30, 2010 | 06:39 PM
dodgeram07's Avatar
dodgeram07
its a 4x4 straight alxe should not have camber adjustment
if a 2wd drive it will have camber
so is it a 2wd and 4wd drive dodge?
Old Jan 30, 2010 | 09:10 PM
95RAM360's Avatar
95RAM360
its 4wd, you can see the diff.
Old Jan 30, 2010 | 11:44 PM
dakotas ram's Avatar
dakotas ram
the pic posted is not his....
and alignment should have nothing to do with this
Old Jan 31, 2010 | 12:03 AM
98ram318's Avatar
98ram318
mine is a 4wd, i did just recently do all new tie rods/steering bars and all that but i matched them up to the old ones pretty well... could alignment have something to do with it? i can roll all of 10 ft while turning the wheel a 1/4 turn back and fourth and it will change from leaning in to out..
Old Jan 31, 2010 | 12:47 AM
dakotas ram
no on the alignment
Old Jan 31, 2010 | 02:50 AM
99DRAM31887's Avatar
99DRAM31887
when my drivers side wheel bearing was going out i had it jacked up and i had my dad try to move it, it had just a small amount of play in it. But i could see the axle shaft moving with the hub assembly and my passenger side my balljoints are going out and i can tell cuz the whole knucle under the top joint moves not the shaft so. There might be some play but it might be very small
Old Jan 31, 2010 | 02:57 AM
dakotas ram
http://www.youtube.com/watch?v=CmuUASXlPYw
Old Jan 31, 2010 | 11:08 AM
yakkier's Avatar
yakkier
Negitive camber is when the top's tilt in towards the engine, positive camber is when the top's tilt out
Old Jan 31, 2010 | 03:15 PM
dakotas ram
and his is doing both, so ball joints or wheel bearings....or 2 bent wheels, lol
