Lifted 2nd Gen's come discuss
Old Jan 31, 2010 | 06:54 PM
wake's Avatar
wake
Default Lifted 2nd Gen's come discuss
ive been having an argument with some friends and family..
when putting a 3 inch lift(from the stock ride height) on a 4x4 truck with solid axles
should the axles be rotated a lil to not stress on the U joints..some say yes some say not
keep in mind..this is with stock 16x7 rims with normal size tires
discuss
Old Jan 31, 2010 | 07:01 PM
freeflow's Avatar
freeflow
your fine with a 3" lift. i run 5" and didnt do anything to axle angles and i havnt had a prob.
Old Jan 31, 2010 | 07:04 PM
wake's Avatar
wake
thats what im saying..i could see if it was 5+ inches of lift..but i think three with the exact size rims i have and tires i have
16x7 rims 265/75/16 tires
lifted three inches..i dont think i should have to adjust the axles at all..not to mention ive got new u joints on the front shaft..and we believe the rear driveshaft u joints are 101K miles old
i could understand if it was gonna be mudding and flexing alot but it wont be that often for a huge suspension flex so it should be good
Old Jan 31, 2010 | 07:06 PM
freeflow's Avatar
freeflow
ya you will be fine.
Old Jan 31, 2010 | 07:07 PM
Gerehead8's Avatar
Gerehead8
When you get a kit with new control arms they help put the axle back at the right caster. At 3in you should be fine but at the limit of the stock control arms. If you take the truck to the shop and have them align it they should adjust the caster with an adjuster on the front of the bottom control arms. As far as the u-joints go they are supposed to be at odd angles and a 3 in lift is nothing to extreme for them.
Old Jan 31, 2010 | 07:13 PM
wake's Avatar
wake
agreed..this is the kit i was considering
http://www.topguncustomz.com/Store/G...iview=25474016
the way i figured it..for the top of the line OEM replacement suspension parts that id like to replace cause everything you see in that kit has had alot of hard plowing done to it..and its sagging lol especially up front
so what i thought was it cant be to much more from the top of the line stock replacement from this lift kit
no obviously its wayy in the future but it doesnt hurt to just talk about it
Old Jan 31, 2010 | 08:07 PM
yakkier's Avatar
yakkier
Your fine, i was running a 6 1/2 on 33's before i took it out half of it and they are fine
